Hi
I have a fibaro heat controller, it supports them with the new edge driver.
Is it possible to add a fibaro heat controller to SharpTools?
Heating control, I think, is something important.
Hi
Have you tried to add it to a dashboard and then click the 3 dots to configure it and select âchange layoutâ?
As what is it turning up on your dashboard?
The problem is that it doesnât show up when selecting an append as it syncs SharpTool with Smarttgings
Hi Damian!
It looks like you joined just 2 days before we made the Next Gen Samsung SmartThings connection the default for new users. As such, it looks like your account is using the legacy SmartThings connection which can only authorize devices that match the set of capabilities in the lists that you mentioned. The ânext-genâ connection authorizes all devices regardless of their capabilities.
Since youâre relatively new to the platform, you have two options:
Works Perfect! Even my SwitchBot curtains are visible in the beta version
Subject settled ![]()
