Fade to Zero on Hue Lights Using SmarThings Edge Driver
FYI for those that might have Rules that run a fade to 0 on Hue lights in SmartThings. With the switch to the stock Hue Edge driver in SmartThings you can no longer fade to 0 - it will only go down to 1. So if you really want the light fully off you will need to add in an additional action to turn the light off.
