F1 information in Sharptools
Hi Everyone. Big fan of F1. I have seen other creators incorporate F1 information onto a dashboard such as Home Assistant. Is there something that can be done with Sharptools. I think it would be cool to be able to see stats and leaderboards. This could work for other sports too.
If there’s a data source available, I suspect it could be integrated.
  • If there’s an RSS / XML feed available, you could use the News Feed tile.
  • If there’s an embeddable webpage with the data and format you like, you could use a URL Custom Tile
  • If there’s an API / JSON source available, you could create a Custom Tile (with the help of Claude, Codex, etc).
They publish a calendar with schedule of events so I’ve added that to my SharpTools calendars: webcal://ics.ecal.com/ecal-sub/69d8226d9b63a5000231074a/Formula%201.ics
How do you add it to SharpTools? Thx.
Hey Don, add it as a calendar resource, then drop it on the dashboard.
  1. Open Manage Resources → Calendars → Create Calendar
  2. Name it (for example Formula 1) and paste that webcal:// URL
  3. Edit your dashboard, tap +, expand Calendars, and add it
More detail here: How do I add a calendar to my dashboard?
If the webcal:// link doesn’t take, try the same URL with https:// instead.
