Enhancement request: Ability to modify the rule on rule engine tile
It would be very useful to be able to modify and being able to select other rule-engine rule of a rule-engine tile after it was created.
This will even greatly empower the “copy” operation, as currently, when having concrete area/room customized tile/rule - copying it to another dashboard is actually useless.
An example: radio stations (before the use of hyperlink workaround for customized logo), each Alexa is controlled and operated by a different rule as target echo is per rule but all other parameters are similar, so if copying a rule tile to another dashboard/room - then I can only direct/link it to the equivalent (echo) rule and I am good to go.
