It looks like there are some ghost tiles getting left on the dashboard which is likely causing the rendering issues. (see screenshot snippet below)
It’s very important that if you see these ghost tiles occur that you discard the changes and refresh the page to remove them. Refreshing the page will remove the the ghost tiles so they don’t break anything. Otherwise if the changes are saved while the ghost tiles are on the dashboard, it can cause the system to try to inject spacers to fill what it sees as ‘gaps’.’
Of course, these ghost tiles shouldn’t occur, so if you start to see a pattern that causes these to show up (maybe dragging or editing a particular tile type?) I would be very interested in hearing about it so we can try to reproduce and fix it!
