Can I edit the temperature value displayed on my dashboard to remove the decimal and just show the rounded temp? 100 vs 100.5 for example. Would also like to remove the F if possible. I need to make the display as large as possible to see across the room and these details are not necessary.
The Hero Attribute Layout has these features.
Edit: And if you need a more customized layout (or want to mix and match data), Super Tiles also allow this level of customization.
A post was split to a new topic: Decimal Rounding Stopped Working?
