I have an Ecolink Firefighter device that doesn’t show up in my device list. It’s online in IDE so I’m not sure why SharpTools doesn’t see it. Any ideas?
James
November 14, 2021, 1:00am
2
@Techno_Vol , you follow the steps in this post to add the device to SharpTools as long as the device handler implements Sensor or Actuator capability.
If the Thing implements at least one of the core supported capabilities, it should be available as part of the normal authorization flow. (Eg. Switch, Motion, Lock, Temperature, etc, etc)
The steps below are no longer required as of January 2023. SmartThings shut down their Groovy integrations and SharpTools transitioned to a next-generation integration with SmartThings which naturally authorizes all devices on an account without having to make selections by capability.
If the Th…
