Ecobee - via ST
I have a Ecobee and other equipment integrated in Smarthings and i found SharpTools to get more features and flexibility.
-I am now able to control the modes and be able to change from heat to Aux heat, we have a Bi-energy tarif that switches to Gaz under -12 and electricity is 3 X cost and the only way to switch the mode was via SharpTools.
Theyre is a feature with IFTTT where it detects when the system is put in manual mode but i can’t get is to detect on Sharptools.
The other IFTTT feature is to ‘Resume’ to automatic mode the Ecobee thermostats, i tried a few choices with no success…
Does anybody kno how the get the previous to features to work ?
Last one is something i tried to find with multiples different searches and can’t find a answer…
How can i see all the different variables returned by Ecobbe / ST to SharpTools ? a kind of ShowAllVariables returned ??
The Alexa skill can resume for Ecobee, so if you use a TAustin virtual alexa switch in SmartThings to know when someone is home/away, you can use it to set away and resume though Alexa custom routines by telling Alexa to set each thermostat to away or to resume schedule. Ecobee doesn’t expose those capabilities to SmartThings c2c integration.
Also, in SharpTools, if you go to Account, click on the ‘…’ for your SmartThings location, then scroll down and click on your device under “Things”, it will show the various capabilities and attributes exposed in SmartThings and to SharpTools.
Thanks @Philip_Peeples i have configured a lot of features in ST, now to get the resume part working in Alexa.
Do you know a way to get a message other then from IFTTT when someone changes the manual mode when setting a temperature and get out of schedule ?
Do you use Pushover?
This is how I have it setup in Alexa with the Ecobee Alexa skill for each Thermostat.
@Philip_Peeples , thanks i will try this way
