I’m working on a Super Tile for my Ecobee Thermostat and am wondering if there is an action that I can assign to raise/lower the set point by one degree. I know that the stock Thermostat Tile allows this, but don’t see an equivalent action.
@Jim_Grotto you can creat rules to lower/raise the setpoint and configure the item’s tap action in the super tile to execute the rule. See the rule example below.
I would like to be able to adjust the temp with +/- (ideally using an IF condition in a Rule that checks the mode Heat/Cool and adjust the appropriate set point) and change the icon based on mode (Heat/Cool).
What integration are you using with your Ecobee?
I have mine connected via Ecobee connect and the Ecobee Suite Smartapp (which will be depricated in the near future). Only the smartapp shows raise/lowerSetPoint commands on mine.
