So any idea what could be causing this? My ecobee sensor is showing a “?” mark between the number and the F…Anyone see this before? (And decimals are not checked, although it doesn’t seem to matter either way)
The unit of measure being reported with the temperature value seems to have a question mark in it.
I usually override the unit of measure on the Hero Attribute tiles so I can have a clean and consistent set of units shown.
°F
Thanks!! Appreciate the assist!
@josh
Regarding Ecobee sensor tiles… how do I get mine to display the temp like Mark? My dashboard shows an large icon instead of the value, and I would rather see the 77F large and centered. Im using Smartthings & Ecobee.
You’ll want to use the Hero Attribute tile:
While editing your dashboard:
- Tap the … in the top right corner of your desired tile
- Tap Change Layout
- Select Hero Attribute
- Optionally: Tap the … on the tile and select Edit to customize which attributes to display and how they are displayed
