Without closing Fully, is there a way to exit out Kiosk mode? I just want to access the Sharptools menu to log out ![]()
You can remove ?kiosk=true from URL to disable the “kiosk mode”. You can configure Fully to enable “Show Address Bar” under Toolbars and Appearance section in settings.
Thanks, I was hoping there was an easier way. I might have to configure one tile to load the non-kiosk view while figuring things out still.
Just a heads up that once you are in kiosk mode, you’ll stay in kiosk mode as you navigate around to different dashboards.
If you hyperlink to the main dashboard listing (SharpTools App), that page will automatically take you out of kiosk mode. Alternatively, there’s an undocumented exitKiosk=true URL parameter that you can add to take you out of kiosk mode.
