The feature/idea is to use tiles which display lines to divide dashboard(s) views into different sections.
- Lines can be set to any height or length (ie 1x8, 5x1) but never wider then 1 tile
- Lines can be different types (solid, dashed, morse dash, etc)
- Lines can be single or double
- Lines can be different strength (ie thin, normal, bold)
- Potential to have overlap tile (ie where lines cross each other and/or meet ie vertical meets horizontal)
The feature helps divide dashboards into different sections when there are many tiles set in the configuration.
