This may already exist and I’m just not able to articulate the right search words.
Here is the ask…
I am making great use of the Device Health API recently released.
I have a rule which runs every few hours, does a health check, if anything is found offline it sends me a notification with the devices and sets a variable to false.
The variable is used to display an alert on the dashboard if the devices are “healthy”
All this is pretty simple…
But, I was curious… Would it be possible to write the “offline” devices to a variable - and then on button click for the above icon, display the contents of the variable in an modal window?
I know you can alter the text of a tile - but given that you never know how many devices may be “offline” - I thought it would be safer to open a window with the list - or some other expanding feature on tile click.
As a work-around, in this very specific case, I suppose I could just do a Hyper-Link action and open the Health Check API again. I’ll just need to figure a way to stylize the output for “public” consumption.
