Does anyone know if it is possible to display the date and time that my motion sensor was last triggered? Thanks
Hi @Brian_Hood , welcome to the community. You can create a Text
variable, and a rule to assign the $context.event.timestamp
value to the Text
variable when Then motion/device is active. Then add this Text
variable to your dashboard. See screenshots below for a quick rule example:
The
context variable will have to be manually input and be wrapped in double mustache brackets. ex{{ }}
. Please note that the timestamp will be displayed in UTC time.
The Text
variable can be created by following these instructions:
Thank you James, that worked! Is there a way to for me to convert this to CST, and then a different date time format?
@Brian_Hood , timestamp context variable conversion and formatting is not currently supported but feel free to post a Feature Request with the detailed use cases so others who are interested can vote as well.
