Hi,
I’m trying to set up integration from Sharptools to Hubitat to Ring. I’ve got 3 virtual switches (home, night, away) in Hubitat and Rule Machine rules there to handle when one of them flips on to make it sync to Ring to disarm, arm home, and arm away respectively. I’ve put the 3 switches as tiles on my dashboard and styled them up so they look pretty good. The problem is… The switches can be toggled so you could turn on Home then click it again to turn it off. What I want is that you can’t click the switch when it’s on, you can only click one of the other ones to turn on that mode. What’s the best way to do this (or if there’s a better way to accomplish what I’m trying to do I’m open to that too).
Thanks!
