Is there a way to turn off my lights that are set up on a dimmer? I only have the option to dim the lights & not turn them off. I am on the Hubitat platform and new to automation.
Thanks
Thanks
Hi @Herb_Michelli welcome to SharpTools family and community. You can change the dimmer switch tile’s tap action to “toggle on/off”. So when tapped it will turn on/off the lights and you can long press the tile to bring up the dimmer level slider.
That worked perfectly!!!
Thanks for the help
