I have added Digital Clock Super Tile:
When choosing 24 Hour format, all minutes are correct.
When using 12 hour format the “0” is missing during the first 9 minutes of each hour. We can underst 12:2 is really 12:02 but it is unfamilar to most folks. Is rhere a way to insert the “0”?
Can you share a screenshot of Date/Time item’s configuration within your Super Tile? I’m not able to reproduce this in a Super Tile with any of the time formats.
I can, however, reproduce it in a regular clock tile where the time format is explicitly set to 12h rather than using the system time.
I pushed an update which should resolve the issue with the 12h format on the regular clock tile. You can refresh your browser page while viewing a dashboard to pull in the latest updates.
