Difference between setLevel and setFanSpeed
I have a rule that turns on a fan for 10 minutes every 45 minutes. The plan is to have it run on medium speed. Since I don’t have the option of High, Medium, or Low in the rule, I’m setting 50 on “setFanSpeed”. It runs at 100%. Should I use “setLevel”? The fan is controlled by a GE Fan Controller, using stock DTH.
It has levels of 0, 1, 2, 3
How can I get this to run on Medium or 2?
Did you try setFanSpeed with a value of 2?
Yep, originally, and it ran at 100%. I tried a bunch of variations…
I just deleted the rule and started over. 1st action: turn On. 2nd action: setFanSpeed “2”.
Now it works… no idea why it didn’t work before. But all good now!
Thanks Josh.
