Date Issues Now We're in 2023
@josh
I’m noticing a couple of issues with dates today. The isBetweenDates Expression is returning false incorrectly:
This evaluated to true yesterday as it should.
The same is happening using the labs equivalent.
Also, the date picker when viewing logs allows you to select a date correctly on first try but subsequent date change attempts brings the picker back up to Jan 28, 2023 and you can’t change it.
Thanks for the tag. I’ve pushed an update to the Labs server as well as the expression system within the Rule Engine, so your date comparison should work as expected now.
I’ll take a look at the date picker for the logs when I’m back in the office.
Thanks @josh.
Happy New Year.
The date picker for the logs is fixed as well. Thanks again for reporting.
Awesome, thanks Josh.
