How to size tiles in Sharp Tools. Don’t have 3 dots in the bottom right of screen.
@Mike_Patterson thanks for posting and welcome to the community.
If you are viewing a dashboard in Kiosk Mode, the ...
in the bottom-right corner will be hidden.
If the dashboard is opened normally (eg. not in Kiosk Mode), you’ll have access to the edit menu in the bottom-right corner.
- Open your list of dashboards: SharpTools App
- Select your desired dashboard from the list by tapping its name
- You should see the
in the bottom-right corner of the screen
