I have a Danfoss LC13 Thermostat [Rad Valve] in my smart things. When I give Sharptools access to all of my things, I can not see Rad Valve in the Sharptools dashboard anywhere.
Even when I authorize Sharptools to access my devices, I can not see options to select Rad Valve under the “Which Valves” option.
Could someone please help me why Rad Valve device is not accessible via SharpTools?
Is this using a built-in SmartThings Device Type Handler or a community developed device type handler? If it’s a community DTH, can you share the link to the relevant community post?
If the Thermostat/Valve doesn’t include at least one of the capabilities that we support (Temperature Measurement, Valve, Thermostat, etc), but it at least supports one of the generic ‘Actuator’ or ‘Sensor’ capabilities, then you may be able to authorize it manually:
