Custom Tile for multi-sensor
Good afternoon all,
I would like to have 1 tile that would show all the readouts from 1 multi-sensor, such as illuminance, temp, humidity, and motion.
Can I achieve that, if so how.
Thanks
Dom
Hi there! Welcome to the community and thanks for posting!
You could use a Super Tile for this.
There’s not a built-in tile that shows all four of the measurements you mentioned and the Hero Attribute tile only allows for the custom display of 2 attributes. The Super Tile, on the other hand, allows you to mix and match data from as many attributes as you’d like (and you could even mix attributes from different devices or variables too!).
