Is there a way to load a custom tile in an overlay?
I recently reworked my Tesla dashboard using the new Tessie Hubitat app. When I click on an image of my car, I want to load up an overlay of a custom tile showing the map location.
Is there a way to adjust the size of the overlay window?
I’m using a dynamic map from Windy.com, from which I created a custom tile. When I load it up in an overlay, the bottom part of the slider is truncated. Is there a way to resize the window to allow it to show?
The option to be able to open other dashboards as an overlay worked beautifully.
I was opening the Windy dynamic map as a hyperlink, so there wasn’t an option to be able to set the width as 80%. Therefore, the map was cut off at the bottom. I ended up creating a dashboard with the embeded dynamic map and use your method to open it as a dashboard. Now, it looks and works wonderfully.
Overlays seem to open centered at the top of the current dashboard. Is there any way to dictate where it opens?
Use case: I have a super-tile map of a room where I can touch a light to turn it on/off. If it is dimmable, I’d like to optionally access a dimmer slider when turning it on. The custom tile ‘Vertical Slider’ does the job so I made a dashboard with just that in it so that I can open it on the dashboard with the map super-tile. But rather than open in the top-center, I’d like to make it open near the light-in-question on the map.
Overlays always open centered and there’s not currently a customization for the position where they open. I’m not really sure how feasible an X/Y style coordinates system would work though as some dashboards are scrollable and overlays always open relative to the viewport of the browser (rather than scroll position of the dashboard itself).
Thanks for the info. Don’t consider changing anything about this for my sake - it’s probably a niche desire. I’ll find a different way to get what I’m after.
