CSS Definition of Switch vs Dimmer
I copied css syntax from the Wiki community. It defines everything ass “switch”. The routine works great for Kasa non dimming switches but doesn’t work for dimmers.
How is a dimmer defined in css coding?
Here is the syntax copied:
.tile.switch .icon {
  display: none;  /* hide the icon */
.tile.switch .title {
  font-size: 2em; /* 2x font size */
  height: 100%; /* fill the full tile height for centering */
  top: 0; /* align to the top of the tile; remove top padding from title */
  display: flex; /* enable vertical centering */
  align-items: center; /* horizontally align */
  justify-content: center; /* vertically align */
/* The style below targets everything in the title
    to make it have a ellipsis if the text overflows  */
.tile.switch .title * {
  white-space: nowrap;
  overflow: hidden;
  text-overflow: ellipsis;
This post shares some tips, including a video, on how you can find the selectors and structure that’s used:
The Switch Level tile layout is .switch-level
