Just to clarify, if you create a Rule which has a Trigger based on your Wallmote button physically being pressed, then your Rule Flow will run when your Wallmote button is physically pressed.
To your point, if you already have a rule setup in Hubitat, then you can create a Virtual Switch and add that to your existing rule. Then you can configure that Virtual Switch to automatically turn off… And use that Virtual Switch in your dashboard.
Edit: here’s a post showing how to configure a Virtual Switch as a momentary switch:
