@josh I try the URL that you suggested but no luck? Thanks for the suggestion.
I’ll see if I can dig out the camera when I get home and figure out what the valid URL is.
Just to confirm, did you enable the MJPEG stream on the camera as noted in the previous post?
I pulled out my Amcrest IP2M-841 camera and did some testing and unfortunately it looks like they only provide support for embedding the username and password using a format which is no longer supported for embedding on Google Chrome and some other modern browsers. (eg. username:password@cameraURL)
I had my camera running through Blue Iris which can be used to consolidate multiple cameras into a single interface and acts as a nice DVR for your cameras. Blue Iris has URLs which work with SharpTools and that’s how I previously viewed these cameras in SharpTools.
If you don’t want to setup Blue Iris, another alternative would be to use TinyCam as a middle-man. Similar to Blue Iris, it can take the video from your camera as an input and then output in a format supported by SharpTools. You can find more details about using TinyCam as a middle-man in this post: Use TinyCam as a middle-man for incompatible camera streams
@josh is there a guide how to set up Blue Iris?
I did a quick Google Search and it looks like Amcrest has a guide on how to get your Amcrest camera into Blue Iris:
The steps are relatively the same for most cameras, so the tips from their article apply to most cameras.
This is a highly summarized version of the required steps, but at a high level you would:
- Download Blue Iris from their website:
http://blueirissoftware.com/download/ - Install Blue Iris on a Window PC.
- Launch Blue Iris and follow any final installation steps
- Click the + button in the top-right frame of the Cameras pane of Blue Iris
- Enter the IP address of your camera and click Find/Inspect
Note: If you have a username/password set on your camera, you would enter the password here before clicking Find/Inspect -
- If Blue Iris finds your camera, you can proceed to tweak settings as you see fit
- Alternatively, you may need to select the Make (Amcrest) and Model and then tweak settings
- Click OK and the New Camera window should appear where you can make further adjustments
- Click OK on the New Camera window to complete the setup
- Make sure the Blue Iris webserver is setup - from the main Blue Iris screen, tap the globe icon at the top of the screen to have it walk you through the web server setup.
Note: Alternatively, you can edit the Blue Iris Settings → Web Server and enable the webserver as James showed in this post.
One setting I would recommend changing is making the Web Server setup to require authentication from Non-LAN only: Blue Iris → Settings → Web Server → Advanced.
From there, verify that you can access the Blue Iris webserver in your browser:
http://blue.iris.ip:port/
Example: http://192.168.1.99:81/
If that’s working, then verify that you can view the camera MJPG stream directly in your browser:
http://blue.iris.ip:port/mjpg/{cameraShortName}
eg. http://192.168.1.99:81/mjpg/FrontYard
If that’s all working, then you can use that camera stream URL as a Media Tile in SharpTools. ![]()
