I have two Vivint Z wave thermostats connected to SmartThings hub and then integrated to SharpTools.
All has been working seamlessly for perhaps two years. Suddenly 3-4 days ago, any command I send in SharpTools gives me the dreaded red bar at the bottom of the screen.
If I send a command in SmartThings — very weird, I know — adjusting the heating set point seems to work as intended for both thermostats. Adjusting cooling setpoint begins the perpetual SmartThings spinning thinker. All reproducible and consistent.
Switching to the “Z-wave Switch” would probably just make things worse, but it does look like the device was migrated to the “Z-wave Thermostat” edge driver.
Since you’re also having issues within the SmartThings mobile app, have you reached out to SmartThings support? It seems like it could be a compatibility issue with the new Z-wave Thermostat driver they migrated your device to and your particular thermostat model.
