O I just connected to hubitat and created a basic dashboard. How Can I add a device like a contact sensor and display the temps, battery level. It only gives the option of showing open or close, and if I edit the tile and click on change layout and click Hero Attribute, it just changes into words. no option to select anything else.
Hi @Albert_Mulder, what contact sensor do you have? After change the layout to Hero Attribute, you can “edit” the tile and select what primary and secondary attributes to be displayed. Were you able to see the list like this?
Aw I missed that detail. Thats what I needed. Thanks!
