Device commands in SmartThings don’t have a concept of directly responding with a value.
Instead, when you execute a command on a device, the device might respond by (asynchronously) updating an attribute. So in the case of the Web Requestor driver, it looks like it’s updating a ‘response’ attribute with information about the response.
The note at the bottom of the attribute list in your SharpTools screenshot explains the data being from a few days ago.
Grayed out attributes do not have event subscriptions and the values may be stale or outdated
If you haven’t used that attribute in a dashboard or as a trigger in a rule, it’s not subscribed and thus the data is from the last time the device was synced over to SharpTools.
@josh, I’m still struggling with this. With the attribute ‘response’ subscribed to in SharpTools, how can I then get that attribute contents populated in a variable?
I’ve taken the two rule approach that you suggested. However, something is not quite right. I have the Web Requestor response both on a dashboard and in a rule yet the response (that is updating in SmartThings) is not updating in SharpTools. It did update when I added it to a dashboard initially but it hasn’t since.
Can you send a note to support with the Device ID in question so we can take a closer look?
I tried setting up a test and the various attributes were updating as expected for me through a number of iterations. I’m wondering if something with the event subscription might have gotten out of whack since this would be something of a one-off event subscription with it being a unique custom capability.
