Hi,
I’ve created some routine in SmartThings Classic app. I want to add it to my Dashboard, but I can’t find it if adding via Location Features. What is wrong ? How can I make my routines available ?
Please advise
Welcome to the community and thanks for posting.
If these are recently created Routines (after authorizing SharpTools), the first thing I would try is reauthorizing SmartThings as the system will resync your data.
- Open your SharpTools.io User Page
- Tap Manage Connections
- Select SmartThings
- Follow the authorization prompts
After you complete the authorization and are returned to SharpTools, you may need to wait a few moments for it to complete syncing the updates over.
thank you so much josh its work
