Was recommended to post here by James
I can’t figure out how to get the robot to start vacuuming. It’s the JetBot AI+ on Samsung SmartThings. I can get it to start from the SmartThings app, but not from SharpTools or IFTTT.
Here is the rule:
Here is the rule:
@Matt_DeKok, welcome to the community. It seems the rule can be triggered by the switch event, but for some reason the command(action in the flow) doesn’t kick off the robot to start to clean. Have you checked the Live Log in SmartThings IDE if any error reported when this rule was executed?
Meanwhile, I don’t have the robot to test with, but you may want to try out different commands. My quick research found this post where the author had to send the following commands in the exact order to activate the vacuum:
setRobotCleanerCleaningMode with argument autosetRobotCleanerMovement with argument cleaningThank you! That worked ![]()
