I can’t change icons on my tiles. Only option is icon states. What am I doing wrong?
Hi @Jerry_Jansen - welcome to the community and thanks for posting!
Tiles that are state aware let you set the icon per state.
For example, you could choose which icon you want for a switch based on if it is ‘on’ or ‘off’.
Thanks but I added tiles for lights, switches, fans, etc. How do I change the icons from the light bulb to something else.
While you have your dashboard in edit mode:
- Tap the
in the top-right corner of the desired tile and tap Edit - Ensure the box next to Icon is checked
- Tap the Icon States button
- Select the desired icon for each state (on/off)
Note: If desired, you can select the same icon for both states
Thanks Josh for your help. Sorry new to this.
My pleasure! Thanks for posting!
