I have an app sending Pushover a notification via email, can Sharptools use that notification to as a trigger, a location change on the Smartthings hub?
What app is sending the Pushover notification? Could you have that app make a web request to a Rule HTTP Trigger instead?
It receives an email notification, which is sent to the pushover email address. The app doesn’t have any other connectors.
Ah, I think I understand what you mean now.
You mean you are sending an email to your special Pushover xxxxx@pomail.net email address which then sends the push messages to your mobile devices?
No, you cannot directly set up a trigger from a pushover notification. Those notifications go directly to the pushover app on your mobile devices.
If you had a device running Android that was receiving those notifications, in theory, you could use Tasker to react to the pushover notification being received on the mobile device and send a web request to trigger a SharpTools rule as mentioned above.
What app is it? Perhaps there’s other ways it could be accomplished.
