I would like to be able to use RTSP links to my NVR and there by get a live feed on a dashboard. The ‘Media’ options are to restrictive as they require an HTTPS connection and that means a whole lot of messing around with secure servers and IP addresses and such. Having said this, I did set up HTTPS to my NVR server via Stunnel and No-IP DDNS but then I found that this app (Sharptools) didn’t support the link on Android or FireTablet tablets. (If you link to a new window, it might work, sorta for a bit. Don’t hold your breath) However, It works perfect on my laptop or computer with Windows OS. I hope the developers can work on this ASAP as I can see I am not the only person looking for a solution.
