Camera on Dashboard
it has been a while, but here we go again.
I have just got a Sonoff slim cam gen 2 . I have it on Tinycam pro rtsp, Onvif all good. can see it there.
how do i get it on Dashboard.
is there new rules, I used to have wyze cam on, but they are gone now
used the nip,io and others, but no go now
You’ll need to get an output from TinyCam in a supported format like image snapshots or MJPEG.
The main article covering all the high-level details about displaying cameras - with links to other detailed articles - is here:
In particular, the above article links to the following community discussion about sourcing camera feeds from TinyCam which has important details about URL formats, how to test, using appropriate username/password formats (if applicable), and disabling the ‘Use HTTPS’ in TinyCam as it uses an invalid cert.
And depending on what browser and browser version you are using, many modern browsers block mixed content in embeds and there are workarounds for that. First step would be getting the basic image snapshot / MJPEG stream running directly in a fresh browser tab to verify the basic connectivity is in place, then if it’s blocked while embedded check the username/password is using an appropriate format, and that you are using the http URL and SSL is disabled in TinyCam, then check the browser mixed-use below.
Ever since Josh got me focused on using TinyCam I haven’t had any issues except the tablet that runs TinyCam will sometimes go to sleep or off-line even though all the settings tell it to stay awake. I use TinyCam to find my Dahua cameras on the same network and then share the webhost feed to Sharptools. Now I have an all cameras dashboard and I can show just certain cams on a home dash.
