Is there a way to make a Calendar tile content “fit to screen”. So for example. in the horizontal layout, only Sat (today) to Wed shows on the screen. Have to scroll to the right to get to Friday. I dont see a way to reduce font size or wrap text or fit to screen. Not sure if I am missing something or the features does not exist.
Would you mind sharing a screenshot showing the challenge you’re running into?
You mentioned that you have to scroll right to see additional content - have you tried making the tile size itself wider so you can fit more content onto it?
So I have the tile as 6 wide. I can certainly make it wider to fit the window, but I am planning on adding other buttons on the right. As you can see, it cuts off the Sunday schedule and I have to scroll right to view the full calendar.
