@Scunny, I personally disabled the the login credential requirement for the LAN network since I have the complete control of my LAN network. However, if you do prefer the login to be enabled, you can include the user and password as the URL parameters, and you’ll have to check “Use Secure Session Keys and login page” option in BI’s web server settings. See the post below.
http://resource/?user=user&pw=password
It depends on if you want to display the camera live view (mjpg) in the dashboard or not. If you use Media tile, you can display the live view in the dashboard and configure the tap action to just refresh the URL source or open the URL in a modal window (to view the camera view in a bigger window prompt). But if you use Hyperlink tile, you can configure it to open the modal window to view the live camera when tapped, but you won’t see the live view within the dashboard itself.
