Is it possible to find values of all atteibutes for an object?
For instance i am working on a rule with wyze home monitoring and i want to see all the data values to help with that rule creation.
I found i can see all of this via the my account and browsing the connection for the device.
Glad you found that! You can see the attributes and their current values within your account.
As for the potential valid values for each attribute, you would generally want to refer to the documentation for your smart home hub. For example, the SmartThings Capability Documentation or the Hubitat Capability Docs.
