If you look at the picture you will see one “Kitchen Moisture Sensor on Office” on the left and two on the right.
What is somewhat stranger is that I picked a variety of different temp sensors earlier from the picker (all hub mesh) but all the things that were placed on the screen were the exact same sensor.
Maybe it will clear up with some elapsed time, maybe not. Are you seeing much activity with Hub mesh?
