I have been wanting to build a dashboard for my TVs in the house but so far haven’t found anyway to do this. I have Apple TV on my main TVs and then a combination of Roku and Fire TV on the others - although I favor Roku as I am able to automate it.
A simple full screen browser would suffice but one doesn’t seem to exist for the Roku or Apple?
I am using Hubitat and Homeseer. I have roku control. I am looking for a way to put a Sharptools dashboard on the roku or Apple TV so I can control the house through the TV. As far as I can tell only Amazon Fire Stick has a browser?
How about an inexpensive Android TV box (dozens of these on AliExpress starting at about £30 or so)
You can run AppleTV on that as well as having a full browser capability.
And looks like you can now run a Roku app on an Android device too
Interesting idea. One of the reasons I chose roku is that I can automate the roku remotely. As it is a Roku based TV I can turn it on and off, adjust volume, load apps etc. will need to check if I can do this with Android TV. Thanks.
I have a firestick and use the Safari browser. Downloaded an App on the firestick called bookmarker 1 (they also have 2, 3, 4 etc). So bookmarker one is linked to my ST main dashboard. So I can holler “Alexa, open bookmarker 1” and the dash pops up and can then be controlled through the firestick remote. I also have bookmarker 2 set to my Blue Iris feed to pop my cameras up on the TV. Pretty happy with the interface overall.
Your book marker setup sounds interesting. I think I’d like to do something like that as well. You say you use the Safari browser on your Fire Stick? How did you go about doing that?
It’s been a while since I set it up, but if I remember right I belive it is as easy as copying the sharptools URL (whichever dash you want to use) into the bookmarker APP upon setup - not much else too it.
