Hi,
added special control for my samsung’s air condition - how do I control with rule the temperature ?
Hi @lior_zilber, sorry I don’t quite understand what do you mean by the special control. Is the device added in the SmartThings, and authorized to SharpTools? If so, when you select this device in the rule action, do you see the command like setCoolingSetpoint
in the screenshot below? This would be the command to set the cooling temperature for example.
Thank you
I needed so turn on the advanced mode but it is exactly what I asked and nedded
