Hello, I am new to the community and just purchased the sharptools product. In the midst of working on the dashboard I came across a weather widget that was interesting to use from weatherwidget.io. The only thing available to embed this is a script but I didn’t see a way for a script to be added to the dashboard in anyway.
Has anyone done this and if so are there any good guides to show how this can be done?
Welcome Ron!
Sharptools is the best. Great product but what makes it the best is the support from James and Josh!
To add something like the weather widget you crest a media tile.thats where you are able to manage scripts and what not.
Go to your main page and find manage resources, then media tiles and create a new one. From there you can add what you need to get the media tile to he a weather widget.
One thing that’s not immediately obvious when configuring theweather.com/widget, is you can set the frame and background to transparent and then use white for the text if you want your dashboard background to show through a bit:
Thanks for the quick replies. I did previously try the weather widget one Josh has shown using the article but I was not all the crazy about it. I like the one from https://weatherwidget.io but after you customize it you only get an html/script option as such:
thanks again Josh, usd to php (philippine peso). i am currently in the philippines and i check the dollar exchange rate every now and then. it will be so much easier to check on it on my dashboard.
