Is there a way to add a “thin” spacer to the dashboard? I’d like a visual way to separate some tiles from others on the dashboard by simply dragging a spacer that is much thinner than a default spacer. (horizontal and vertical resize)
Thoughts?
Thoughts?
The only way to do this is to adjust your dashboard column size to something larger and then adjust each tile size.
Here’s an example with scalable column rows 29, each device tile is 2x2
Thanks Terri. That’s what I’m currently doing, but it’s a bit tedious. I thought there might be an easier way… edit a few spacers as opposed to edit many tiles…
