Ability to set default tile paramenters
I would like the ability to create a default set of parameters for a given tile.
A use case is being able to specify the battery level threshold as a default set of parameters instead of having to change every single tile for every device that has a battery, in my case dozens of devices.
Thanks for posting! I can certainly understand the use case for wanting to define a default set of battery thresholds (as noted in your other post), but I could use some help in understanding the use cases for making this a broader feature for setting default tile parameters.
Are other use cases you have in mind?
