120 minute temperature notification
Hi, I have a Temp sensor in my garage and would like for it to send me a temp update. I installed AC and I would like to monitor it. I have pushover and text capabilities. Is this possible to do?
You can do that using a variable changing as a trigger. See @Chris_C 's solution for how to loop, in your case every two hours. If you need more detail, post back
Hi, I will give that a try. Thank you for the direction.
