HI James,
Thanks for responding.
Pardon me if i will sound naive because i am pretty new to this area.
What i used is simply to create Stream using VLC, however i could not see any option to create MJPEG stream, i see options like “File”, “MPEG”, “http”, “RTP/MPEG” etc. options. I simply created “http” stream on port 8082. Later i test it by opening it using “Open Network Stream” using that http://:8082 and i am successfully able to open this stream using VLC.
Can you share on how to disable the auth requirement to VLC ?
thanks and regards
Lalit
