Tile status issue...help
i’ve just import new light switch from ST. it is sonoff t1 us via tasmota dh. when i press the tile - the lights turn on and when i press again - the lights turn off. the problem is that i dont see the tile change color when its active while other tiles change colors when active ,dow different DH and type of lightning…
Does the tile reflect the proper switch status in the bottom-right corner of the tile as you turn it on and off? And does the icon glow when the device is turned on?
Do you have the tile color overridden on individual tiles or also at the Dashboard Settings? If it was done per-tile for the other tiles, you’ll want to double check that you have coloring setup for this tile as well.
