I’m very new to home assistant and smart tools, been been using HomeSeer for 10 years.
It’s possible. I’m being stupid, but I’m really struggling to get my head round a thermostat set point issue.
Setup - Tado , Home assistant, Smartools
Version - all up to date at time of this post
The issue I’m seeing is that the heating setpoint shown in Smartools, isn’t always matched to the one shown in HomeAssistant.
HomeAssistant seems to match Tado - obviously there’s sometimes a delay of about 5 minutes)
I’ve played around on a test dashboard, pulled all the various settings in to see if I can spot anything, but I’ve hit a wall.
Any idea appreciated
James
April 7, 2022, 6:26pm
2
Hi @Jonathan4 welcome to the community. Does your thermostat supports both heating and cooling? If so, you can change the Thermostat Tile to “Double Height Thermostat” layout, which displays the heating and cooling set points separately.
Or can you please send an email to support@sharptools.io with the screenshots of what you are seeing in Home Assistant and SharpTools, along with the diagnostic file that can be downloaded at the addon’s diagnostic page?
Hi, thanks for quick response.
The one I’m currently testing is heat only.
Log follows, screenshots attached
Tado room screen
Home assistant
Standard Smartools heat tile
Super tile screen
The screen with the super tile also has tiles with the various Tado values - max, min, setpoint, temp. As you can see, setpoint doesn’t match HA
J
Log
2022-04-07 20:33:02 info: Received command get_entity from SharpTools.io .
2022-04-07 20:33:02 info: Send binary_sensor.side_door_open’s state_changed event to SharpTools.io .
2022-04-07 20:33:03 info: Received command get_entity from SharpTools.io .
2022-04-07 20:33:04 info: Received command get_entity from SharpTools.io .
2022-04-07 20:33:05 info: Received command get_entity from SharpTools.io .
2022-04-07 20:33:06 info: Received command get_entity from SharpTools.io .
2022-04-07 20:33:20 info: Send camera.drive’s state_changed event to SharpTools.io .
2022-04-07 20:33:38 info: Send lock.gym_door’s state_changed event to SharpTools.io .
2022-04-07 20:33:42 info: Send lock.gym_door’s state_changed event to SharpTools.io .
2022-04-07 20:33:59 info: Send binary_sensor.side_door_open’s state_changed event to SharpTools.io .
2022-04-07 20:33:59 info: Received command get_entity from SharpTools.io .
2022-04-07 20:34:01 info: Received command get_entity from SharpTools.io .
2022-04-07 20:34:02 info: Received command get_entity from SharpTools.io .
2022-04-07 20:34:22 info: Send light.kitchen_down’s state_changed event to SharpTools.io .
2022-04-07 20:34:23 info: Send light.kitchen_ceiling’s state_changed event to SharpTools.io .
2022-04-07 20:34:23 info: Send light.kitchen_pendant’s state_changed event to SharpTools.io .
2022-04-07 20:34:38 info: Send binary_sensor.side_door_open’s state_changed event to SharpTools.io .
2022-04-07 20:34:39 info: Received command get_entity from SharpTools.io .
2022-04-07 20:34:41 info: Received command get_entity from SharpTools.io .
2022-04-07 20:34:41 info: Send binary_sensor.side_door_open’s state_changed event to SharpTools.io .
2022-04-07 20:34:42 info: Received command get_entity from SharpTools.io .
2022-04-07 20:34:44 info: Received command get_entity from SharpTools.io .
2022-04-07 20:34:45 info: Received command get_entity from SharpTools.io .
2022-04-07 20:34:46 info: Send binary_sensor.side_door_open’s state_changed event to SharpTools.io .
2022-04-07 20:34:47 info: Received command get_entity from SharpTools.io .
2022-04-07 20:34:48 info: Received command get_entity from SharpTools.io .
2022-04-07 20:34:49 info: Received command get_entity from SharpTools.io .
2022-04-07 20:34:50 info: Received command get_entity from SharpTools.io .
2022-04-07 20:36:04 info: Send camera.drive’s state_changed event to SharpTools.io .
2022-04-07 20:36:07 info: Send sensor.gym_door_battery’s state_changed event to SharpTools.io .
2022-04-07 20:36:07 info: Send lock.gym_door’s state_changed event to SharpTools.io .
2022-04-07 20:36:10 info: Send sensor.kitchen_temperature’s state_changed event to SharpTools.io .
2022-04-07 20:36:10 info: Send sensor.kitchen_heating’s state_changed event to SharpTools.io .
2022-04-07 20:36:10 info: Send climate.kitchen’s state_changed event to SharpTools.io .
2022-04-07 20:37:40 info: Received command get_entities from SharpTools.io .
2022-04-07 20:37:40 info: Received command add_subscriptions from SharpTools.io .
2022-04-07 20:39:17 info: Send sensor.living_room_co2’s state_changed event to SharpTools.io .
2022-04-07 20:39:17 info: Send sensor.living_room_humidity_2’s state_changed event to SharpTools.io .
2022-04-07 20:39:17 info: Send sensor.living_room_pm1’s state_changed event to SharpTools.io .
2022-04-07 20:39:17 info: Send sensor.living_room_pm25’s state_changed event to SharpTools.io .
2022-04-07 20:39:17 info: Send sensor.living_room_pressure’s state_changed event to SharpTools.io .
2022-04-07 20:39:17 info: Send sensor.living_room_temperature_2’s state_changed event to SharpTools.io .
2022-04-07 20:39:17 info: Send sensor.living_room_voc’s state_changed event to SharpTools.io .
2022-04-07 20:39:40 info: Send camera.drive’s state_changed event to SharpTools.io .
2022-04-07 20:41:04 info: Send camera.drive’s state_changed event to SharpTools.io .
2022-04-07 20:41:09 info: Send sensor.kitchen_temperature’s state_changed event to SharpTools.io .
2022-04-07 20:41:09 info: Send climate.kitchen’s state_changed event to SharpTools.io .
2022-04-07 20:41:22 info: Send light.kitchen_down’s state_changed event to SharpTools.io .
2022-04-07 20:41:23 info: Send light.kitchen_ceiling’s state_changed event to SharpTools.io .
2022-04-07 20:41:23 info: Send light.kitchen_pendant’s state_changed event to SharpTools.io .
2022-04-07 20:42:44 info: SharpTools socket is disconnected. Reason: transport close
2022-04-07 20:42:44 info: SharpTools socket connection is established (X267cOi8kBRgL6D_AAAx).
2022-04-07 20:45:17 info: Send sensor.living_room_co2’s state_changed event to SharpTools.io .
2022-04-07 20:45:17 info: Send sensor.living_room_humidity_2’s state_changed event to SharpTools.io .
2022-04-07 20:45:17 info: Send sensor.living_room_pm25’s state_changed event to SharpTools.io .
2022-04-07 20:45:17 info: Send sensor.living_room_temperature_2’s state_changed event to SharpTools.io .
2022-04-07 20:45:17 info: Send sensor.living_room_voc’s state_changed event to SharpTools.io .
2022-04-07 20:45:50 info: Rendering index
2022-04-07 20:45:55 info: Received command get_subscriptions from SharpTools.io .
2022-04-07 20:46:04 info: Send camera.drive’s state_changed event to SharpTools.io .
2022-04-07 20:46:10 info: Send camera.drive’s state_changed event to SharpTools.io .
2022-04-07 20:46:10 info: Send climate.living_room’s state_changed event to SharpTools.io .
2022-04-07 20:46:11 info: Send sensor.home_weather_condition’s state_changed event to SharpTools.io .
2022-04-07 20:46:11 info: Send sensor.home_outdoor_temperature’s state_changed event to SharpTools.io .
2022-04-07 20:47:34 info: Rendering index
2022-04-07 20:49:22 info: Send light.kitchen_down’s state_changed event to SharpTools.io .
2022-04-07 20:49:23 info: Send light.kitchen_ceiling’s state_changed event to SharpTools.io .
2022-04-07 20:49:23 info: Send light.kitchen_pendant’s state_changed event to SharpTools.io .
2022-04-07 20:51:04 info: Send camera.drive’s state_changed event to SharpTools.io .
2022-04-07 20:51:10 info: Send sensor.kitchen_temperature’s state_changed event to SharpTools.io .
2022-04-07 20:51:10 info: Send climate.kitchen’s state_changed event to SharpTools.io .
