Hello. It looks like when trying to synchronize my Home Assistant with ShaprtTools.io, it gets stuck on “Processing” and never finishes the synchronize. I was trying to add my Ecobee thermostat to SharpTools.io. I wonder if it got into a bad state because I had originally used SmartThings to add the Ecobee thermostat to SharpTools.io, and I hadn’t removed that integration before trying to sync Home Assistant. I’ve since removed the SmartThings integration, but it still always seems to get stuck when trying to sync Home Assistant now, so I think it must be in a bad state.
Thanks for the details, Pat. Your account’s Home Assistant authorization was stuck in progress, so we’ve reset it on our side. Please try syncing again.
If it gets stuck again, it’s likely something in the device sync itself is failing. A couple of questions to help narrow it down:
Has anything else changed recently? For example, did you authorize any new devices, or install a major update to Home Assistant or one of its integrations? If you added new devices, try unchecking them to go back to your previous device selection, then reauthorize.
Check the logs for the SharpTools App in Home Assistant (add-ons are now called Apps). They often give a clue about what’s failing.
If nothing stands out, please do a diagnostic export with all the boxes checked, along with the SharpTools App logs from around a fresh reauthorization attempt, and send them to us in a private message.
