They would need to implement at least one of the supported capabilities, then all of the capabilities should get exposed once the device is authorized under any of the capabilities. For example, it’s common to implement the Switch capability alongside the Switch Level capability.
Alternatively, since the components implement the Refresh capability, you may be able to authorize them manually as noted here:
